Joining a Tuner’s Network
To submit files to a tuner, the customer will need to join the tuner’s network. Follow these steps:
1. An invite code from the tuner is required. If the customer does not already have an invite code from the desired tuner, they should contact the tuner and ask for one.
2. If the Account screen is not already displayed, select the ACCOUNT button in the navigation bar.
3. Tap the LINK TUNER tab. Enter the invite code and select SUBMIT.
4. The below screen will appear, select OK.
5. If the tuner automatically accepts requests to join their network, you should receive a confirmation popup almost immediately. Otherwise, you will have to wait for the tuner to manually approve your request.
6. Once the tuner has accepted your request, they will appear under the LINKED TUNERS list.
7. Tap JOIN.
8. If you no longer work with any tuners under your LINKED TUNERS list, select REMOVE next to the tuners name on the right.
